I think you have to go to the dealer for the alignment bolts.ekes said:Will the shop doing the aligment have those bolts?
http://www.prgproducts.com/titan_leveling.php40seven said:Where did you buy the the PRG kit?
If you have an '08 and you have less than 12000 miles, it's a freebie via the TSB..... That means, NO CHARGE. Look into it right away if you want it done!chepdog said:so the bolts are $350.00 to buy in order to make the alignment work on an 08, what a crock of $hit. Sounds rather pricey to buy some bolts or maybe you mean the whole alignment issue through the dealer. Let us know for the ones that already know. Thanks
EVO8 said:Guys, you DON'T need the camber bolts for doing the 2" leveling kit from PRG. Only the toe in is affected. The alignment shop only needs to adjust the toe. Don't waste your money on camber bolts, it's not needed.
Just installing the level kit will not mess up your camber. Greg (PRG) even says that. When I installed mine, everything was in factory specs except the toe. I did a toe measurement before and after, and the toe was out about 1/2 inch after the install. When I had the alignment done, everything was within spec except the toe. Looks like your camber issue was before you leveled your truck. If the kit was installed correctly then no issues should be seen but there are always those very rare occassional ones.gyrate said:explain how you would adjust the camber without the bolts then? my camber was all fubared at 7k miles. it's a must do upgrade, for whatever reason
