what i wanted to know is if anyone has just that leveling kit on their 4wd?
Many do
Secondly, is the coil bucket hitting?
Not if you have the correct kit installed, there is a difference between the 2wd and 4wd kits
Thirdly, do you have to compress the spring to do the install
No, the spacer goes ontop of the stock assembly
do you have to disconnect the sway bar?
Yes
Should take you less than 2 hours since your a newbie.
With this kit, do I have to get an alignment?
Yes
www.prgproducts.com
Many do
Yes
Yes
www.prgproducts.com
