I have a 2004 Titan SE, want to put on a 2.5 in front and 1 or 1.5 in rear block, I'd like to put on Nitto Terra Grapplers in the LT325/65R 18 which measure out to 34.88 inches and 12.99 inches wide, would this rub?? Would I be better off with 325/60R 18 which are 32.99 and 12.83 wide? Not gonna wheel with it besides minor hunting/fishing excursions. Thanks
Discussion Starter · #2 ·
Forgot to mention, it's a 4x4 and would I need to upgrade to bigger shocks?
You might get away with the 60's tires, but if you jump up to the 65"s you will have rub issues at the mudflap, do a search for "pinchweld mod" to see if that's for you...
You shouldn't need "bigger" shocks for only 1-1.5" in the rear, but you might want to start budgeting for at least a set of Bilstein replacement shocks, the stockers suck...
If you're staying mostly onroad, might as well just get the 60's. Tell you what, when you're done, there won't be a fishing spot misssed. This setup has gotten me through some messy crud. :thumbsup: Downfall is that I'm drinking down 10-12 MPG's now. Good Stuff!!! :D
You might want to reconsider putting a 2.5" kit on you 4x4. The upper control arms will hit the coil buckets. A 2" front spacer will work better on your 4wd.:D
Super Moderator
I'll second what Blavis posted, and if your shocks are original it would be a great time to upgrade them. Especially if you're going over a 1" rear block.
Thanx everybody, now I just need some dough to get all these goodies!!!
