I had the same issue as you after alignment (PRG mini lift). It just didn't feel right so I took it back again for an alignment and it rode better afterwards (in my mind anyways). The toe in was just slightly off by a little but nothing big enough to feel. It personally won't ever ride like stock again because you have changed the dimensions of your suspension designed. I would suggest that maybe you should get the camber bolts so the alignment guy has more room to tweek it. It shouldn't cost you anymore money for the alignment again, just complain that it's still pulling to one side and they will take care of you.
