1 - 2 of 2 Posts
Hey guys I got my Pro Comp Stage II lift and started reading through the manual and had a couple questions about some the parts. In the pics attached what is the square flat metal plate with the 4 bolt holes? Also the kit came with only two of the sway bar mount extensions (the bottom metal plate in the pic. In the instructions it says to use 2 on each side using the OE bolt, I wouldn't think the OE bolt would be long enough. The plates are pretty thick. Also if I'm gonna be running the CST sway bar endlinks do I need to still run the "steering stop reinforcement" that the instructions say to use with the Pro Comp sway bar endlinks? Any other info or pointers would be great guys, thanks..!!!
1 - 2 of 2 Posts
