Hey guys had a guy install a 6 inch pro comp lift on my titan, but now it seems as though my steering rack and pinion shift a little bit if I max out the steering in either direction causing my steering wheel to be off center.
I understand that most people who have this problem simply install new poly rack bushings to fix it, but my problem is that these pro comp poly rack bushings have already been installed.
I've verified personally that they are there - I can see them in place yet for some reason my rack still moves ever so slightly. Anybody have any insight into this problem?
Thanks
Discussion Starter #4
Torqued the rack bushings a bunch more and she's good now, does anyone know if the rack is self centering? My wheel is off center now wondering if I should just get my steering wheel re centered or to try and get the rack positioned perfectly
