Yes the rear HD's ride a little rough. I would get the 5100's or the 5125's from greg at prg. The price point is not that big from the 5100's to the HD's. I have 5100's all the way around the fronts set to 1.5" of lift. They are a little stiff but I like them. FYI: the 5100's on their lowest setting will give you. 05" of lift maybe more on a pro-4x.I only got 100 miles on the odometer currently but I read everywhere how the ride is better with Bilstein 5100s , so the HD will also improve my ride with better confort ?
If you replace your ranchos with bilsteins you will feel a night and day difference. Factory ranchos suck.More confused , those rancho knock because the coilspring is to long , they have a technical bulletin with coilspring replacement to solve the problem , I think that bilstein with the same coilspring didn't have this problem right ?
Ditto what Book said; replaced stock Ranchos a few months ago with Bilsteins all around with front on lowest setting and T rides better than new.If you replace your ranchos with bilsteins you will feel a night and day difference. Factory ranchos suck.
Technically no. You would not need to get it aligned. I would just to be safe. The 5100 rears will not add ride height. HD's front and 5100's will be awesome. Pull the trigger already. If you don't like them throw them on here in the buy sell section, they will be gone in an hour.If i used the hd front and the height sont change I Will not
Need to do realigment , is the rear 5100 change height ?
I paid $341.81 shipped for all 5100's at all four corners from ShockWarehouse.comhow much do the 5100's run a set?
