1 - 13 of 13 Posts
First things first, this has nothing to do with gas mileage. My 2004 Titan only get 280-300 miles per tank when my low fuel light goes on. I only fill up approx. 20-21 gallons leaving 7-8 unused gallons. My buddy fills up with 25-26 gallons when his light goes on. A service tech told me it may be a bad sending unit which could cause poor fuel pressure. Does this sound right? Could this effect anything other than having to fill up more often. I have 95000+ miles and this wouldn't be covered by Nissan and I wouldn't pay to fix it if it doesn't effect engine performance. Any guidance is appreciated.
It sounds normal. I would rather have a 50-60 mile buffer when the light comes on rather than a 15 mile buffer, especially when on the highway at night. Sounds like your buddy's low fuel warning is not working.
Dont trust the gas gauge... Mine ran out of gas Saturday and the gauge said i had .25 tank left????
Both my truck take 21 gallons when the fuel light comes on.
Super Moderator
The sending unit won't affect engine performance, just the fuel gauge readings. And yours sounds normal to me too.
I had the sending unit replaced after a few months I bought the truck, wouldn't go to full even with full tank. 6 months later, it started to drop below full again but not as bad as before. Dealer said it's normal but I know it's doesn't work as when it was brand new. There was lots of posts bout this problem about 2 yrs ago.
Mine also takes 21 gallons when the fuel light comes on. Also this has happened twice in the last monoth, when I fill up it takes almost 20 minutes for the gas gauge to get back to FULL.
I just went thru my second sending unit this week , under warranty , but a royal PIA. Nothing like having the needle peg below E and still have 5 to 6 gallons left. I'm truly surprised this issue isn't a TSB.
My light normally comes on at around 22 gallons.
Just had my sending unit replaced under warranty. I filled up one day and it didn't register full until about 20 miles. It only did it once but I told the dealer it always fluctuates so they would replace it, and they did. Don't we have an 8 gallon reserve in our trucks. That would make up for the missing 8 gallons.
Your gas tank readings sound about normal. Mine is the same way, never goes all the way to full. I can drive about 35 miles and it reads 3/4 of a tank. I am having mine replaced this week or next. I just get angry cause i spend almost $90 filling the phucker up and it is a 3/4 a tank very quickly. That's just me filling my neurotic need though on that. I get the avg mpg's as everyone else so I know it's not a problem. I just want the phucking saticfaction of seeing a full tank after dropping a pretty penny at the gas station.
If your truck isn't under warranty and you need this replaced, it will cost you about $500-$600 large................
1 - 13 of 13 Posts
