How many miles do you have on the truck ? Where are you located ?cemj said:
ohhhhhh, and there's an e in intermittently
FYI Higher millage vehicle's are prone to carbon buildup that can cause this issue .... easy fix....
How many miles do you have on the truck ? Where are you located ?cemj said:My Titan will intermittntly crank without starting. Eventually (between 30 seconds and 10 minutes) it will start up. Anyone else have this problem? If so, what is it? The dealer says they have no idea what would cause it and they can't fix it without creating the failure.
Yahooligan said:There is a chip in the key (The keys with the silver Nissan logo are the ones, the ones without the silver logo don't have the chip) that sends a signal to the control module telling it to start. If this is faulty then the engine will crank but not start. Your truck should have come with 2 such keys and a 3rd non-chip spare key. Try using the other chipped key and see if the problem goes away.
