OK guys quick run down:
i was coming from drill and it was a windy night , going up a hill and against the wind i had the truck in CC MPH, and the truck at some points struggle to keep speed and down shifted(very expected since i put a shift kit in it) but almost at the top it started to loose power and the CC shuts off. i was like WTF
, once going down it was so windy that i didn't notice it
but once i got to "flat" surface and i tried to punch it , it was not responding properly like if something was broken :huh: after i made it home and i check again so windy that i couldn't tell what it was.
today i decided to drive it with a lot less wind and it sounded like
1-coil took a dump on me
2-bad spark plug
3-bad wiring
after checking th plugs with a meter, we came to agreement that they are good.
the wiring was looking good so only one thing left
and yeah the sparks plugs(the one we checked) was very wear down and they don't even have a year...
so I'm like :huh: how is this possible for a so EXPENSIVE and "tested" plug. tomorrow I'm going to get a set of NGK and replace all of the plugs and ill get back to you guys..
i just wanted to share my experience and maybe someone else had the same problems..
2-bad spark plug
3-bad wiring
