When you swapped out the rear end what did you do for wheel sensors? My assumption is the computer is looking for data from the rear end for traction control and it's not receiving what it needs.
Yeah, it has no wheel sensors on the rear end. Witch is what I figured the problem was but I’m still not sure how to fix it cause the rear end is the most expensive part on the truck I’ll change everything else to get it to work cause that rear end is not coming off that truck haha.When you swapped out the rear end what did you do for wheel sensors? My assumption is the computer is looking for data from the rear end for traction control and it's not receiving what it needs.
Currie talks about tone rings here:
[/QUOTE thanks I did a lot of reading but from what I saw they really only talked about gearing and there replacement rear they were developing around the time I put my rear end on my truck. but can you install tone rings on a rear end that wasn’t originally designed with them or can I re- program or replace my ECU so I don’t need the rear sensors?![]()
Currie Ent Titan replacement Rear end
I posted this in the General section earlier, We (Currie Ent ) are thinking of developing a replacement 9 inch and D60 rear for the Titan.. We have nothing yet. I need feed bake from the people on this forum as to what you use the trucks for and what failures you have had. The more response to...www.titantalk.com
