Hey guys I have a 2010 Nissan titan CC with 8k miles. I bought the truck a few weeks ago and it already had the lift kit on it. So after driving it, it seems to randomly pull.. sometimes to the left and sometimes to the right, I have never had a lift before so I'm not sure if this is the lift and bigger tires ( 305/55/20r Toyo Open Countrys) I took it into 4WheelParts and they hooked it up to a machine and told me that it looks like it was never aligned after the lift was put on, so he aligned it but it still pretty much feels the same to me. Anyone know if this is normal?. Thanks!
could be just the nature cup to the road....most roads are higher in the middle to deal with rain so it goes to the shoulder naturally instead of pooling and collecting....the tires are a lot wider than stock or a normal tire so what ur prol feeling is just that...ur following the shape or contour of the roads....plus u might not have a sway bar on so it will feel even stranger....hopefully its not something more serious but im pretty sure thats what ur dealing with
Is the tire pressure correct in all the tires? I run 33'' Toyo MTs and run like 45 psi and it rides fine... If the lift was installed correctly and there was an alignment done then there shouldn't be any issues... I took the sway bar off and love it... Remember if you take it off don't do crazy stuff like swerving back and forth to see how it handles... I haven't had good experiences with 4 wheel parts but it could just be the shop by where I live...
Thanks for the advice I checked the psi and two tires had 40 and the other two had 35 so I moved them all to 45 and it seems to ride alot better. Also kinda wondering if anyone could help me out on this, when I take off from a stop, not giving it a ton of gas but a good steady acceleration it seems to slip... at first I thought it was just the tires spinning but I don't see how I could spin the tires with the amount of acceleration I am giving it. But it doesnt feel like a tranny slip, it feels like its in the rear. Any ideas?. thanks!
Its most likely axel wrap nothing a set of traction bars wouldnt fix
Sent from my samsung fascinate using the auto guide app
