The kit comes with brake lines. Dont let them bs you about that. as far as the cam bolts, what problems are they having?
i think they said that the right rear was hitting something i will give a better description tomarrow morning when they reopen. they said they cannot adjust realignment becuase of it.PrerunnerGreg said:The kit comes with brake lines. Dont let them bs you about that. as far as the cam bolts, what problems are they having?
fastcrazyhurt said:i guess it's also missing a lower camber adjuster bolt. so now i'm waiting for to parts while i'm out a truck. the dealer sells the fabtech but after reading all the info on here i wanted the procomp so later i could add the SAWS from PRG. Procomp needs better quality control to make sure that the parts are in the box.
fastcrazyhurt said:the dealer said that the right rear doesnt' work that it hit the cam disk or something so they tried a fabtech one and it did work. maybe its just the wrong bolt they sent with my kit. i know that the fabtech works with saws also but i heard better reports on here about the procomp lift.
