Supporting Vendor (Gold)
Hey all,
Just letting everyone know that we’re running a special on Pulstar now until the end of June.
If you’ve wanted to try out Pulstar plugs, now is a better time than ever! Just type in TTPULSE10 at checkout to receive 10% off of your order.
Questions? Email me at [email protected]
Thanks!
I went to your website and couldn't find the pulstar plugs on the applications for a 06 xe model.
The reason for this is that up until '08, the titans were using a special NGK double iridium fine electrode plug. For whatever reason in '08, they switched to a regular NGK iridium plug. According to pulstar, and if you look at the specs, a pulstar plug will work for that motor, but there was some reason that special plug was being used.
We are going to have a guy with an '06 test the pulstar in his truck and see what happens. So you can wait and see how that goes, should have results within 2 weeks or so, or you could order up a set and see for yourself. You'd just have to specify an '08 titan to find the plug.
