You can't use the Q45 TB, they are cable operated and not DBW like the Titan. There was talked about it but it cannot be made to work.
TitanBlue said:Lookup PGM, Project Giant Mouth.. It is the only viable upgrade, and has proven results. It uses a Corvette (GM) TB, and is 90mm.
No you use a reducer. I have a 90* one that goes from 4" to 3".djmars20 said:Would an aftermarket intake fit over 90mm? how about the stock intake?
Thrust_Titan said:All of the Titan TB's are the same 04-08
When you buy the PGM, it comes as a complete pkg to fit your system. You supply the TB, they do all the modding needed to make it fit. First batch of 10 are done, or very close. Another batch will hopefully be offered in the fall. Nice way to complete a truck that refuses to get headers or NOS. It'll fly with that thing, good for another 20HP or so, with UpRev tuning.djmars20 said:Would an aftermarket intake fit over 90mm? how about the stock intake?
BBK is the one stillen is working with i believeFlippin Pips said:I believe Stillen is working on a TB.
