Can these be used on top of the DR's so I can keep them around the 2" facory preset for softer ride and still get another inch with the spacers? This would be the same as cranking the DR's to 3" right?
can u explain why?NorCal 4x4 said:Do you mean the spacer that comes with the PRG 4" Performance Package?
If so, yes, but you also need the aftermarket UCA, like the Total Chaos or PRG's, and an external bump stop, (droop stop).
I'm not an suspension expert, but I think I remember that it's because, adjusting the preload collar will not affect droop, but the length of the coilover does. The DRE is already at the optimal length for the stock UCA, so adding a spacer takes away droop travel. Where the stock coilover is shorter so the level kits don’t have as much of affect until they get above the recommended level kit height. So with the DREs, and spacer you will hit your stock UCA against the bucket. With the aftermarket UCA no hits.TitanmediC said:can u explain why?
That's my quote from another thread...You can set the ride height what ever you want, the shock length determines if the UCA/ball joint will be an issue or not.
Since the DR's are stock length, and the stock UCA's can handle a .625" spacer, the Camburgs should be "way fine"...IIRC the motion ratio is 3:1 so a .625" spacer should give you about 2" of lift...
so is my previous post accurate? r u saying u ran the spacer on top of the DR's with stock UCA's and no banging? thats my goal as i'm just trying to fit my 315/70/17 BFG AT's on the stock OR wheels that i have sitting in my garage. keep in mind those tires are around 60% tread so i'm guesstimating that they're around 34" diameter at most.loufish said:...Yes you can run a spacer for height and then keep the preload down to keep a softer ride...I did the same thing with my 4" lift spindles, reduced preload to get a better ride.
I was under the impression the DREs were longer than stock, but still a stock application. Designed with the knowledge that there were a couple of inches to play with, as shown by the level kits ... therefore, (if I'm correct), a 5/8" spacer on top of the DRE, would require the aftermarket upper A-arms, otherwise why does the 4" Performance Package, come with the uppers? idkloufish said:That's my quote from another thread...
The stock suspension setup will tolerate a 5/8" spacer and MOST stock UCA's will be fine, but there have a been some that still hit the coil-bucket with that spacer.
Since the DR is stock length, MOST trucks should be able to run the stock UCA, but no promises...
Since people clear the 34.5" dia. LT315/70/17 on the XE and O.R. wheels with a PRG level kit, (some have to do the pinch-weld-mod, and others don't), that sounds like if you level the Titan with DREs, (and nothing else), 2" on a 4x4 and 2.5" on a 2wd, then you should have an equal chance of clearing.TitanmediC said:so is my previous post accurate? r u saying u ran the spacer on top of the DR's with stock UCA's and no banging? thats my goal as i'm just trying to fit my 315/70/17 BFG AT's on the stock OR wheels that i have sitting in my garage. keep in mind those tires are around 60% tread so i'm guesstimating that they're around 34" diameter at most.
which I'd planned to ask Greg sometime is ... with the 4" PP, (an aftermarket UCA, and the spacer already on), and if lowering the Titan to 2.0" or 2.5" of lift, would it be better to keep the spacer and set the preload lift to 1" or 1.5", or to remove the spacer and set the DREs to 2.0 or 2.5"?Me said:My question,
Being the humble man I am, I could be wrong...We'll have to wait for Judge Greg to make a ruling...I was under the impression the DREs were longer than stock, but still a stock application. Designed with the knowledge that there were a couple of inches to play with, as shown by the level kits ... therefore, (if I'm correct), a 5/8" spacer on top of the DRE, would require the aftermarket upper A-arms, otherwise why does the 4" Performance Package, come with the uppers? idk
I have the DR coilovers with the 5/8" spacers and TC arms,TitanmediC said:k so the tire clearance shouldn't be any issue. now we're still stuck on the UCA/coilbucket issue. i thought the DR's were longer as well, but fit stock apps. just want to know: do DR's + PP spacer = banging coilbuckets? if so at what setting on the DR's does it become an issue?
well if so many people are having coilbucket issues with a 2.5" lift via spacer wouldn't i with say DR's at 2" and spacer giving total of 3.25"?BECHLYF said:I have the DR coilovers with the 5/8" spacers and TC arms,
and when my truck is at full droop the TC arm's have about 1/8" clearance from the coilbucket.with that sad I believe the stock arms would hit.
the coilover lift rule is 2 to 1, if you crank the DR's 1/4"= 1/2" lift.
so the 5/8" spacer give's a free 1 1/4" lift to what ever you have the DR's set at. so yes you can get your desired lift with less preload with the 5/8" spacer.
how ever I also believe a stock A-arm would hit, it does not have the clearance a tubular A-arm does.
so you can use the 5/8" spacer to accomplish a couple things.to get a desired lift with less preload or to get more lift period. my .02
the DR's lift is 3" the spacer makes it 4 1/4".![]()
YES although it's not the shock adjustment but the spacer.TitanmediC said:well if so many people are having coilbucket issues with a 2.5" lift via spacer wouldn't i with say DR's at 2" and spacer giving total of 3.25"?
lets say the DR's are installed and when your truck unweights the suspension drops and the stock A-arms are 1/2" from the coilbucket. ok you install the 5/8" spacer and the DR's is now mounted 5/8" lower and now the suspension can drop 5/8" more allowing the stock A-arm to come in contact with the coilbucket. you need tubular A-arms to use the 5/8" spacer.they have more clearance.I have the DR coilovers with the 5/8" spacers and TC arms,
would you mind letting me know what your fender height from middle of fender to the floor is? so measure from floor (center of wheel) to the edge of the fender pleaseCan these be used on top of the DR's so I can keep them around the 2" facory preset for softer ride and still get another inch with the spacers? This would be the same as cranking the DR's to 3" right?
Just FYI, that measurement also throws the tires into the equation. A more accurate measurement of lift would be from the middle of the center cap of the wheel to the bottom of the fender.would you mind letting me know what your fender height from middle of fender to the floor is? so measure from floor (center of wheel) to the edge of the fender please
