Question about subs and amps
627 7
If i am running 2 single voice coil 4 ohm subs from 1 mono amp what would the amps ohms be running at?
Also can anyone tell me what 2 dual voice coil 4 ohm subs from 1 mono amp be?
I have been away from car stereo for too long.
Does anyone know of a good installer in the Knoxville, TN area?
1 - 8 of 8 Posts
It all depends on how you have them wired........series or parallel. Do you know which way they are wired?
If the subs are wired (+) to (+) and (-) to (-) you are currently at 2 ohms. If you wire 4 ohm DVC subs in this matter your final resistance will be 1 ohm.
Thanks again and last question for a bit. Are these good subs for one of Tech's 12in box?
MB Quart RWE-304 - MB Quart 12" 1000 Watt Reference Series Subwoofer
1 - 8 of 8 Posts
