When I remove the front strut assembly to install the daystar lift is there any specific way to line up the top of the spring hat? On my civic the top of the strut assy. the hole wasnt in the center. Is the hole in the center of the hat? Can I put it any way I want as long as it fits? Anybody torn down the front struts for daystar lift did you put it back together the same way it came off or did you not keep track of what bolt was up front of the top three? there is a small hole in the top of the hat, is that used to line up the front?
