1 - 3 of 3 Posts
I cant seem to find out if the 2005 SE with tow package has a limited slip from the factory. Im still new to the titans and i have noticed in a straight line it will pull posi but in the turns only the outside wheel will pull.
I believe all Titans have ABLS - or electronic limited slip. Uses ABS sensors to determine that wheels are spinning at different speeds. Not a true limited slip differential like you would find in a Truetrac or the like.
The ABLS will apply brake pressure to just the wheel thats spinning, but still not a locker and a poor limited slip...But it does work, I've had some low traction situations where I could feel one wheel spinning, then the other.
It works, but it's not ideal.
1 - 3 of 3 Posts
