2019 Titan Crew Cab SV 2WD
I going next week to get my radflo 2.5 reservoir rear shocks psi checked and wanted to know what is the recommended psi level? I have read online any were from 200 to 275 psi and just want to get the correct amount.
I run anywhere from 125 around town to 275 when Im out in the desert, 200 is the base line. Also the volume of n2 is so small I dont recommend checking it with a tire gauge, you either need a no loss chuck or just set the regulator on the N2 tank to what you want and push it on. Checking it with a tire gauge you will loose a lot of the N2 PSI, if you dont have a N2 tank I would wait to mess with the tell you find someone with a tank.
yea thats what I'm doing, taking it to 4wheelparts this week and get them refilled up. They wanted to know what psi I wanted them at, thanks for the reply.
