Your OEM cap leaks? Weird. I picked up a Nismo branded one off ebay a few years ago and it's been fine. Matches all the other Nismo stuff I have under the hood.
Bending the tabs a tiny bit tighter will often solve the problem. If you use a cap that has a spring in it, you may blow your rad seam as the pressure relief is in the Plastic Bottle Cap. You do not want to change the system design. Let it flow....
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
