From a functionality stand point there is nothing wrong with this piece but its driving me crazy knowing its not how it should be. Its only the bottom left corner that wont stay clipped. Can i fix it or will this piece need to be replaced? The truck is a 2011 pro 4x
Motor vehicle Automotive design Vehicle Car Audio equipment
Hard to say. Does it sit flush and you have to pull it out to see any issue? Is the clip broken? Without knowing what's bothering you beyond what we see in the pic, hard to say. If you have to pull on it, probably a bad or broken clip. If so, either mod it or replace it.
The clip doesent look broken but it dosent sit flush even when im not lightly tugging on it like its not latched in place like it should be. Can the clip be replaced or will the whole piece need to be replaced instead?
From the angle you have pictured it almost looks like it might be hung up on the bottom left of the head unit.
