I am the new owner of a 2015 Titan that came with the combination radio/maps/phone/Blue Tooth/etc., and a touch screen.
My problem is that when I turn the headlights on, the screen gets so dark I cannot see the map.
When I turn the headlights off, the screen is bright and easy to read.
I have tried adjusting the dash lights brightness, but that does not seem to affect the radio screen.
I have played with the night/auto setting on the screen itself but I am not sure what, if any effect it had.
My headlights do NOT have the "AUTO" setting that brings them on whenever the engine is running. I only have "OFF", "PARKING LIGHTS", and "ON".
I like to run headlights on dim whenever the engine is running. But when I turn them on, the radio/map screen gets dark.
The owner's manual says:
Anybody else had that problem and figured out how it works?
Thanks.
ETA: I just checked and at night the radio/map screen is readily visible (well lighted) when I turn the headlights on. In the daytime, when I turn the headlights on, the screen gets REALLY dark. It must have something to do with the ambient light sensor.
I am also not sure what some of that means.Display - Touch this key to adjust the appearance of the display.
- Brightness - Adjusts the brightness of the display.
- Display Mode - Adjusts to fit the level of lighting in the vehicle. Touch key to cycle through options. “Day” and “Night” modes are suited for the respective times of day while “Auto” controls the display automatically.
- Scroll Direction - Adjusts the direction of the menu scroll. Choose to either move up or down.
Thanks.
