Not positive, but when you select your channels (am/fm), you should have FM1, FM2, and AM. There should be six presets associated with each, thus giving you 12 FM's and 6 AM's.
When I traded my '05 for my '07 today, I noticed I had the same problem as you. I had read this post yesterday and began to play with the presets. You can change them. Just push the "FM/AM" button until "A" is highlighted. Then just preset 6 fm stations. Then highlight "B" and program 6 more FM stations. Then highlight "C" and program your AM stations. How your originally programed your radio, screwed it up, it's an easy fix.Truckerger said:Unfortunately, mine is already set for am1 am2 and fm. Just wanting to know if it can be changed to fm1 fm2 and then only one am. If anyone knows how. Or I can just go back to the dealer and ask there. probably $'s for that tho. Thanks T-ger
