1 - 2 of 2 Posts
I just bought some rbp 94r 18x10 with a 10 offset and I was wondering what the biggest size tire i could put on a 2wd titan with 3inch level and 1.5 inch block thanks
Supporting Vendor
Tire & Wheel Specialists
You may be able to get a 305/65R18 under there but is hard to say without a test fit. An 18x10 with a +10mm offset isn't common. The new Falken Wild Peak is available in this size. You may want to look into them. Give us a call if you would like a quote.
1 - 2 of 2 Posts
