1 - 2 of 2 Posts
Hello,
After I completed the JVC HU install I found the system making a loud "pop" whenever it was turned off. Called Crutchfield and learned that I may need to install RCA filters between the HU and amps. Each filter has two thin (18 gauge perhaps) brown wires that they tell me are to be grounded.
Can I "piggyback" these grounds onto my existing grounds that I have for the main unit and ASWC interface? Or would they need their own grounding?
Thanks,
SP
You can use the same ground. The ground loop isolators that I used didn't require to be grounded.
1 - 2 of 2 Posts
