1 - 2 of 2 Posts
I have a 2wd cc titan and the manufacture date on the sticker inside the door it was built july 2007. I'm trying to figure out if I have to old style or new rear axle in my truck. Any part numbers I can match up?? I talked to the dealer and they acted like they didn't know there was even a difference. thanks
debate about door jamb sticker: http://www.titantalk.com/forums/tit...ning-if-i-have-big-tow-not-4.html#post1898958
2008+ have the larger diameter 35 spline axle shafts. I think 2007 went to 4 spiders, at least in the e-lockers.
There may be a sticker on the rear axle (most often found on the passenger side) that has a number, although maybe it has washed off by now. DANA previously used to stamp identifying codes in the axle housing, but apparently not for the Titan.
1 - 2 of 2 Posts
