I was changing out my rear pads and rotors when I found my right passenger side caliper piston has a chunk broken off. Now I will need to change the caliper. My question is how do I remove the brake line hose connected to the caliper without stripping it? I have tried finding videos to no avail any help/pics or links are appreciated
You probably need a line wrench and a little heat.
It might be easier to remove the line further upstream in the brake system and then remove it from the caliper on a bench.
