I don't think so...If that was the case Titan owners would have had a finned cover (aftermarket covers for the 44 have been around for years)to install in 04' before the factory installed one...Any cover for a Dana 44.
Going by illustrations on www.maghytec.com, the standard Dana 44 has 10 bolts, and the Nissan has 12 bolts. Not much standard on the Nissan Rear, but that's OK. No Jeep will do what it does for me.loufish said:I don't think so...If that was the case Titan owners would have had a finned cover (aftermarket covers for the 44 have been around for years)to install in 04' before the factory installed one...
Sorry, my bad. I knew it was a bastard Dana, but to just eyeball it under the truck, the cover looks identical.TitanBlue said:Going by illustrations on www.maghytec.com, the standard Dana 44 has 10 bolts, and the Nissan has 12 bolts. Not much standard on the Nissan Rear, but that's OK. No Jeep will do what it does for me.![]()
Not in the name of time/money trying to get a new product on the market. Especially when you haven't realized yet that your product has an overheating problem.loufish said:I don't think so...If that was the case Titan owners would have had a finned cover (aftermarket covers for the 44 have been around for years)to install in 04' before the factory installed one...
What did that run you?SirKeats said:i just did mine yesterday. courtesy parts sells the whole kit with everything you need (except the gasket... you'll need to add a tube of that before you check out). i took my time so it took me a couple hours, but worked out great. fit my '04 perfectly. i'd highly recommend doing this mod... if for no other reason than piece of mind.
also, my two cents on the oem finned alum cover vs. the AM products. if you look at the stilen and the other one (haytag or something?) they hold more fluid, but they have fewer and shallower fins. with respect to cooling, i'm of the opinion that having more fins is better than more fluid. the goal is to dissipate the heat. sure... more fluid will take longer to heat up initially, but once it's hot, it's hot. if you're not dissipating that heat, you're as bad off as you were before. the OEM finned cover has pretty deep fins and twice as many as the stillen cover (not sure about the haytag one). i definitely think it's the way to go. of course, others will surely disagree so this is jmho.
Sorry...How much did you get the finned cover for?SirKeats said:what do you mean... cover wise or oil wise? i went with the oem alum finned cover with mobile one 75-140. took about 2.5 quarts.
or were you asking something else?
130 bucks for the kit (cover, bolts, bracket) plus a couple more for the tube of seal and then whatever shipping was (i think like 15 or so).bigjimbo said:Sorry...How much did you get the finned cover for?
I won't disagree...you're right, getting rid of the heat is the name of the game!also, my two cents on the oem finned alum cover vs. the AM products. if you look at the stilen and the other one (haytag or something?) they hold more fluid, but they have fewer and shallower fins. with respect to cooling, i'm of the opinion that having more fins is better than more fluid. the goal is to dissipate the heat. sure... more fluid will take longer to heat up initially, but once it's hot, it's hot. if you're not dissipating that heat, you're as bad off as you were before. the OEM finned cover has pretty deep fins and twice as many as the stillen cover (not sure about the haytag one). i definitely think it's the way to go. of course, others will surely disagree so this is jmho.
