Super Moderator
Well, they're cooling fins. So yeah, a heat sink of sorts. :huh:
It is, basically. The first Titans(04) came with a steel, smooth cover. The 05's and later came with the aluminum cover with heat dissipating fins.
Old
New
Banned
2008 titan se crew said:
I have a 2008 titan, what is on the rear end, it looks like a heat sink. any one know?
Looks like someone needs to go back to the dealer, and get a lesson in what is on your truck!!
In addition to stouter inner and outer bearing materials and seals, the differential now uses a stronger 4-pinion setup unlike the 2-pinion configuration in the 04-07 models. See the Sept 07 issue of Four Wheeler.
