Rear locker
7547 Views 8 Replies 6 Participants Last post by  bestatchess
O6 nissan titan with locker in the rear. Luckily I havnt ever had to use it, but in the past I have played with it but the light on the dash just blinks. The other day I crawled under my truck and noticed 2 wires either cut or broke coming off my rear end. Anyone...........?
1 - 9 of 9 Posts
I believe it only locks in when in 4wd low. What were you in? 2wd? 4hi? 4lo?
The cut wires may very well be from the elocker controller, but like others said: it must be in 4 low for the locker to work.
The e-locker includes a solenoid and a position detection plunger in the pumpkin. The position detection plunger connection is the one closest to the front of the truck. A harness goes to both the connections. I think the harness goes to a control unit inside the cab on the rear cab wall. The 2004 service manual (see specific manual for your truck) shows V and Y colored wires going to the coil of the diff lock solenoid and W/R and B colored wires going to the position switch.
My best guess (which may be wrong) is V = violet Y = yellow B = black and W/R = white with red stripe
The manual contains detailed diagnostics using Consult II or using a volt meter.
1 - 9 of 9 Posts
