My rear passenger door lock will not unlock, not from inside, not from front door panel or key fob. It tries but the actuator will not disengage. I removed the door panel and tried to manually unlock it so I could access the screws to remove the actuator, but There was no way that I could find to manually unlock it. Does anyone know a trick to getting it open so I can replace the actuator, without taking it to the Dealer?
