Just want to know which wire is the power wire on the rear sensors that I could splice into for the red power wire of my rear camera I have installed. I have already tied into the reverse light and grounded to the chassis but there is a second red power wire coming off the cameras yellow video input. The problem is this wire is too short so the rear sensor seems to be the closest point to tap into.
I have ran the main yellow video input to the monitor and spliced into an ignition wire up front but I get nothing when I put it into reverse so this leads me to believe this second red wire needs to be connected as well. Although I have read that this wire doesn't need to be connected and can be capped and taped up. I am a bit lost at this point. Any help would be huge. FYI it's a 2011 SV Crew Cab. Here is a link to the exact type of camera and wiring setup I am installing.
https://youtu.be/LPuWODfOeOw
