so are you saying that if you had the c/o cranked all the way up it would be about 2" lower in the back?? I'm curious because I'm planning on getting a similar setup..
blackberry farm said:Any advice on bilstein shocks in rear and donahoes in front on a 2006 CC 4X4 SE? My concern is towing. The stock shocks stink when a load is put on. Will the billsetins hold the weight better? I have a friend who uses Rancho air shocks, am considering those as well.
Your post wasn't that clear, you already have the 2.5" Deaver mini-pak, but it's still lower then the front? And it sags?Does anyone have or know someone that has a 4" or bigger block on the rear with the 2.5 deaver pack on a 2wd. I have SAW c/o's and the rear sags too much, my c/o are cranked just under 1 inch and the rear is almost an inch lower. If anyone has this, have you had any problems with this set up.
I don't get it, with out lift spindles, a set of SAW's with about 1.5" of lift would barely level a Titan with a stock rear spring pak, let alone a 2.5" mini...By installing a rear 4" block, you're saying you need about 6-6.5" in the rear just to keep it level with the front...O.K, I bought the SAW's and cranked them to 1-1 1/4 preload, at the same time I bought the 2.5 deaver springs. Truck still seemed low in the rear so Greg at PRG got me a 3" block, now still the rear is 3/4" lower then front. I'm looking to see if anyone is running a 4" block on 2wd without problems.
Thank you!The guy has a bracket lift!
