Agreed...you would also think they could get the front and rear differentials right also...but did that happen....noooooo...Seriously? A differential should outlast the engine and transmission of a vehicle and in addition you should be able to pull something in reverse without exploding the housing on the front differential. :flame:I received it, but immediately trashed it.
At 112k miles, I'm SOL on the cracked manifolds. If Nissan wants to send letters, they should send a recall letter on these poorly made manifolds.
It amazes me that we placed a man on the moon over 40 years ago, and vehicles have been around much longer than that. With the technology we have, you would think that something as simple as an exhaust manifold would be bullet proof by now.
Sorry for the rant. I get mad every time I think of the problems I have with my truck.![]()
Well if they are cracked they are leaking and vice versa.Do the manifolds have to be leaking to get replaced?
Did the ticking go away after just a few seconds? Mine ticks for about 5 seconds or so when i start it up, and then it does away, and my gas mileage has been less than great.Well if they are cracked they are leaking and vice versa.
Mine was noticeable...ticking sound when the vehicle was first started up in the morning that would eventually fade away after the manifolds heated up and expanded.
Horrible horrible gas mileage when they are cracked also.
Mine were cracked and just had then fixed last week. My gas mileage was horrible before and is nit much better now. The truck is quiet as hell now though.Well if they are cracked they are leaking and vice versa.
Depends on the morning temp. Where I live it can be 20 below zero or 75 in the morning depending on the time of year.Did the ticking go away after just a few seconds? Mine ticks for about 5 seconds or so when i start it up, and then it does away, and my gas mileage has been less than great.
Same here I've got the ticking at startup but dealer says no leaks…I got my card in the mail today. I have a ticking sound for the first 10 seconds or so on startup. I'm sure my T with 69k miles has at least one leaking manifold. Been to the dealer twice and they say no leak. Not that I expect great service from a dealership.
