1 - 1 of 1 Posts
OK someone please help.. The remote starter flashes the parking lights twice after going into remote programming and I don't know why.. Here is how I have everything hooked up:
Connector 1 (CN1), 6-Pin
Pin 1 White – Accessory 12V positive (+) output. – Connect to Red at Ignition Switch Harness
Pin 2 Yellow - Starter 12V positive (+) output. - Connect to Blue/Green at Ignition Switch Harness
Pin 3 Green – Ignition 12V positive (+) output and input. - Connect to Black/Red at Ignition Switch Harness
Pin 4 Black - Ground negative (-) input. – Connect to Ground
Pin 5 Red - Constant 12V positive (+) power input. - Connect to Green at Ignition Switch Harness
Pin 6 Green/White – Parking light positive (+) - Connect to Red/Blue at Dimmer Switch on Dash
Connector 3 (CN2), 20-Pin: Programmable Output Connector (POC)
Pin 5 Red/Black [POC 2] – 2nd Starter 250mA negative (-) output. This output can be used to trigger the prewired relay located on the main ignition harness. – Connected to violet wire on relay for 2nd starter.
Pin 6 Light Blue/White - Brake 12V positive (+) input. - Red/Green At Switch Above the Brake Pedal
Pin 17 White [POC 8] - Horn honk 250mA negative (-) output. - Red/White In Harness at Steering Column
Pin 18 Gray/Black – Hood Pin negative (-) input. - Connected to Ground
Connector 5 (CN4), 6-Pin
Pin 4 Blue - Unlock 250mA negative (-) output. – Ran wire to RED wire at switch in door.
Pin 5 Blue/Black - Lock 250mA (-) negative output. - Ran wire to BLUE wire at switch in door.
Blade-AL(DL) NI4 Firmware
White/Black – Immobilizer Data Vehicle Side – Connect to Brown Pin 4 on Immobilizer
White/Red – Immobilizer Data Connector Side – Connect to Brown Pin 4 on Immobilizer
Brown/Red – CANH – Connect to Blue Pin 6 on OBDII
Brown/Yellow – CANL – Connect to Pink pin 14 on OBDII
Orange/Black – Immobilizer Data – Connect to Brown Pin 4 on Immobilzer
Orange – Immobilizer Clock – Connect to Green Pin 2 of immobilizer
Gray/Red – Ground – Connect to Ground
Any ideas why I can't get the remotes programmed?
It's a Compustar CS6200 with Blade-AL bypass and RF-2WG9-SP Two Way Remote Kit..
Thanks
1 - 1 of 1 Posts
