1 - 6 of 6 Posts
I have a camper shell that is going to bump the rear High Brake light & cargo light combo. It does not have screws through the cab and looks like it sticks on with double-sided tape? guessing?
It runs across the back of the cab. If i can remove this, it will enable the camper i own from my other truck to slide right on!
Any ideas?
Thanks
Love my XD with Cummins!
^^^ What he said. I bet there are screws on the inside. You may have to remove the headliner to get at them.
Reactions: SFGUY
No not n the 2016 so we gently pulled back the overhead and pulled out the four. This is a wide assembly. Looks like a small hole for the wiring and i think the center is recessed into the cab a little bit. The sides are curved aerodynamically and they go out almost to the width of the cab. Looks like they are held down with double sided tape.
i will pull it off this morning and seal that. Then my camper shell will slide right into place. The way it is curved, I think it will be a nice fit with enough clearance to allow independent movement of the cab and bed.
Did you get the High Mount Lamp assembly off? You mentioned "pull out four" 4 what? I'm asking because I need to replace mine. I have 2018 XD and can't find anything on the web except your comment. Could please explained what you did to remove your light, any info would greatly be appreciated.
according to Nissan (what do they know right?) there are three nuts on the interior side...
http://www.nicoclub.com/FSM/Titan/2016 Titan/2016 Titan XD/EXL.pdf
Page 143
also
http://www.nicoclub.com/FSM/Titan/2016 Titan/2016 Titan XD/INT.pdf
page 32
1 - 6 of 6 Posts
