I need to replace a map light bulb and not sure how to get it out...any help...and does anyone know the bulb size or number.
Thanks
Thanks
Go back up to post #4 and watch the video.i am also trying to replace the map lights. i've got the 2004 titan. upper console is one unit. does the lens cover come off or do i need to take the WHOLE console off?????? got the bulbs from dealer...
I tried poping mine out. Interesting that the video starts with the lens being easily removed. Mine was not that easy and I removed the entire console to prevent breaking the lens. Good luck which ever way you decide to go. :ftard:i am also trying to replace the map lights. i've got the 2004 titan. upper console is one unit. does the lens cover come off or do i need to take the WHOLE console off?????? got the bulbs from dealer...
LOL, the service manual actually have you removing the whole console.I tried poping mine out. Interesting that the video starts with the lens being easily removed. Mine was not that easy and I removed the entire console to prevent breaking the lens. Good luck which ever way you decide to go. :ftard:
Yeah, I couldn't help but notice that also.....and on the re-insert, it's backwards, not reversed???? With the tapered end going up and over to the side, first, to allow for the flat lip to slide up and in.....Interesting that the video starts with the lens being easily removed. Mine was not that easy and I removed the entire console to prevent breaking the lens.
Sorry, I should have also posted that your instructions over at MT (referenced in a different thread) were much more helpful than the video.
