Removing Resos? Any improvement?
920 6
I got an Armada now not a Titan BUT theyre pretty similar SO Im wondering... I installed the Gibson side swept exhaust with the Y Pipe back but right after the Y Pipe there is a Reso and then from there it goes to the muffler and then out the back...
What will be the difference without the reso? Will I get more sound if I remove it and replace with a straight pipe? What is its purpose? Just to deaden the sound a lil more?
Resonators are generally used to "tune" the note(s) of the exhaust. They may/probably will make it louder when removed, but the note or consequental drone may be displeasing. Also, some have said that removing the res'(s) give it a "popping" or raspy sound that is displeasing at WOT above a certain rpm's. Hope this helps.
If you still had your Titan you would of had about 10 responses about now. Now you are a mada owner and get the silence.:cheers:
