Replacement Upper BallJoint Boots?
4744 3
The rubber boot that protects the ball joint on my stock upper control arm is torn. Is there a replacement available?
Thanks. Hoping to upgrade to the PRG units in the fall, but would like to get this fixed before the snow flies!!!!
Hmm i too would like more info on this. both sides mine are leaking cause of changing the front suspension 3 or 4 times, andd then the actual blot started spinning as i tightened the nut. Do i have to replace the whole thing? do i have to take off the whole upper a arm to "press" out?? hopfully someone understands my Q
