1 - 2 of 2 Posts
No reprograming necessary, I changed mine out quite a few years ago now and its been fine. I will tell you though it can be a real PITA to change, because of its location. If I remember correctly I had to disconnect and remove the ABS module in order to get enough room to remove it, which then meant that I had to bleed all the brake lines.
1 - 2 of 2 Posts
