1 - 13 of 13 Posts
The service manual that came with the truck (04 Titan LE) included the repair/maintenance information for every light but this light.
I'm wondering if anyone can explain to me how to take it apart, because my father and i are having a hell of a time accessing it.
simple,
in the back seat up on the back wall above window, on you should see 2 small covers, pry off and using a 1/4 inch socket set> i cant remember the specific size but using a ext. through the hole, i replaced mine in about 10 min.
k
your talking about the two little circle things on the roof right, for the things i pry off?
Discussion Starter #9
ight thanks
soo i have the entire light, plastic and all that i ordered, not just bulbs, cause the plastic was cracked.
i can replace it the same way i'd do the bulbs, yes?
ight thanks
Yes, once you get the old housing off, just go in reverse steps to get it back on. Be careful with them bolts, I hear they tend to fall into the headliner.:D
I use a little tape in the socket to make them fit a little tighter when putting the bolt back on.
Where'd you order the plastic piece at? Mine is all messed up and being held together with duck tape lol.
1 - 13 of 13 Posts
