Im changing up somethings.
I dont know if it is my wiring or something, but my right side will not work a majority of the time. When it does, they almost sound blown. Anyway, I bought 2 sets of 6x9 speakers.
Do I need to purchase an amp to power the speakers , or should I be fine?
Also, can I replace my rear speakers with 6x9s with out a big hassle?
6x9" 3-Way speaker system
Mounting depth: 3.51"
Peak output per pair: 1,100 watts
550 watts max each speaker
220 watts RMS per pair
110 watts RMS per speaker
Freq response: 110W 43Hz-24kHz
Those are what I was going to go with.
They will sound OK without an amp, but would definitely sound better with an amp!
The rear doors are 6.5". It would be easier to just replace with the same size.
Yes, but I cant seem to find many good 6.5 speakers, so if it wasnt that much trouble Id just replace them all with 6x9s
also, would I go with a 4 channel amp?
yep, use a 4 channel amp. Get in touch with Tech12, he had a great deal on CDT's going on, a 6-1/2" co-axle for the rear. You'll have to cut some metal to fit the 6x9's.
Discussion Starter #5 (Edited)
Alright thanks, Im looking into an mx12 or mx15 with an audiopipe amp, but theres really no point in doing so untill I can play music.
what is this tech12 i keep reading?
