You dont loose much, as fluid only circulates through the cooler when the engine is running. There is some residual in the lines but again, not very much. If you need to top off with ATF stick with Nissan branded. Check fluid level with the dipstick...be sure to use the correct side of the stick (hot or cold) based on engine temp.
