I was looking to put 20 x 12's on my 2015 Pro-4X. The suspension is stock. The truck looks level already. What offset and tire size should I go with to avoid rubbing? I do want them to stick out about an inch.
go to customoffset.com and check out the Titan gallery. you should be able to find what your truck would look like as well as other setups in case you change your mind and you like a different setup
Thanks for the information. I stumbled on the site a few days ago and found the look I was going for. I ordered a set of 20 x 9s with -12 offset rims and Nitto 33" Ridge Grapplers.
