1 - 2 of 2 Posts
Hey Guys,
Hopefully someone can point me in the right direction.
My '09 Titan SE King Cab 2WD just starting vibrating at high speeds in a strange way. First off, let me say I have searched countless hours before posting, and haven't found anyone describing similar symptoms.
Between 60 and 80, it vibrates in a rolling fashion. Like it is ramping up. If I was to graph it, it would look like an sine wave, like an AC voltage curve. Vibration is in the wheel, seat, and floor.
I have tried balancing, as well as I changed out all 3 U-Joints, making sure to phase the shafts. Also, I looked carefully to see if any shaft balancers came off.
What should I try next? A front end alignment? I'm hesitant to try that next, because if I have to change the tie rods out, I'll have to align again. trying to stay on a budget. Any help on what to try next would be most helpful.
Thanks in advance
Have someone drive behind you and view your wheels at that speed. My Son had a truck do that and he had a bent rear axle. Wheel will look like it's wobbling. Good luck!
1 - 2 of 2 Posts
