Howie Kaluha said:
As far as I remember when the dealer showed me how to work it last week when I bought it, you can't roll them up with the key, only roll them down.....
POWER WINDOW CONTROL BY THE KEY CYLINDER SWITCH
When ignition key switch is OFF, front power window LH and RH can be opened or closed by turning the front door key cylinder LH to the UNLOCK / LOCK position for more than 3 seconds.
-- Front power windows can be opened as the door key cylinder is kept fully turning to the UNLOCK position.
-- Front power windows can be closed as the door key cylinder is kept fully turning to the LOCK position.
-- While performing open/close operation for the windows, power window is stopped when the door key cylinder is placed in the NEUTRAL position.
-- When the ignition switch is turned ON while the power window opening operation is performed, the power window opening stops.
Keyless Power Window Down (open) Operation
When key fob unlock switch is turned ON with ignition switch OFF, and the switch is detected to be on continuously for 3 seconds, the driver's door and passenger's door power windows are simultaneously opened.
Power window is operated to open and the operation continues as long as the key fob unlock switch is pressed.
