1 - 14 of 14 Posts
yes lifted rancho 4inch but still have around 3 inches before i hit top of garage opening
With three inches of clearance, you might be pushing it...but a rough country mount shouldn't add more than that. You could probably shoot them an email for exact height, or maybe someone here with a similar setup can measure and chime in.
I can take a measurement how high above the roofline they sit when I get home but I'm thinking 3" is too tight. Better make sure you don't ever over inflate your tires.
Worst case, just air down to enter your garage, then reinflate every time you roll out before you hit the road! :hahano:
Someone needs to fab up a light bar like the Warrior concept, but with more lights obviously...
That very well may be the sexiest truck I've ever seen. I'd kill for one of those.
I know right. If they actually produced this I would go so far as to put in a preorder.
I make and sell these really high quality light bar brackets to a company called SocalSuperTrucks. We sit the light bar as close to the windshield and as far down as possible to give it the cleanest look we can. And heres a pic of mine for reference, if you need an actual measurement let me know, and ill get it to you.
EDIT: Heres a link to the brackets online:
http://www.socalsupertrucks.com/200...ht-led-light-bar-roof-mount.aspx#.VrLVYtIrLZ4
Discussion Starter · #13 ·
2004-2014 Nissan Titan 50" LED Straight Light Bar Roof Mounts
thanks bro for the information and link.. i will order from them(you) since they made it for the same light bar I'm planning to mount 'RIGID INDUSTRIES 50 E-2'
I've been looking at a roof bar, curved, with mounting points 52 1/4 inches apart (50 inch lighted surface). Would those mounts work for that application?
EDIT: Nevermind, I see it says for straight only. In that case, does anyone have any ideas for a set of brackets that would work?
1 - 14 of 14 Posts
