Rough Country 2" Leveling Kit
644 Views 2 Replies 2 Participants Last post by  el_davicho
Hello fellow Titaneers, I am sure this has been covered in the past but I tried searching here with no luck. I am also a noob to this site so that search may very well be user error. I have a 2015 SV CC 4X4 and I inquired with RC if installing their 2" leveling kit required UCA and/or end links as well. They responded that as long as my truck was not a PRO4X I did not need them. My question is, what is the difference between a non-PRO4X (S, SV, SL 4X4) application and a PRO4X application? I thought that the only difference between them was that the PRO4X came with different struts up front but nothing more. Can someone please enlighten me as I am slowly getting to know my Titan and the differences between models. Thank you in advance.
1 - 3 of 3 Posts
Not much of a difference between Pro4x and other models, suspension wise, except as you say the pro4x have different struts and shocks. But RC is wrong, anything over 1.5" on a 08+ 4wd will require new UCA's. Typically 1.5" does not require endlinks.
Thank you FishnAlaska for confirming my thought. I looked up all front suspension parts (UCA, LCA, coil springs, struts, USM, and end links) on Courtesy Nissan's website and all parts for 4WD and PRO4X had the same part number which made me question their acclamation.
1 - 3 of 3 Posts
