I had a 4 inch rough country lift kit installed on my 05 2wd SE and every time I turn just a little bit I hear a squeaking also when coming to a stop there's a lot of noise almost like a crunching sound any ideas on what to do or what to have shop look at
Id try checking a wheel bearing, mine did this as well. Mine would only make noise when on the ground though, if i jacked the truck up,there wasnt enough pressure on the bearing to simulate the noise. I just new because it had a whole lot of play in it. Bought a new one from Rock Auto for $120 and the sound went away.
Any competent shop should be able to diagnose a squeak pretty easily though, only so many things it can be.
Discussion Starter #4
I don't think it's a wheel bearing it's more of a squeak doesn't shake or anything and it only happens when my wheel is turned I tried greasing all the places there are bushings but no luck
